Revit Server Documentation?
2 REPLIES 2
LisaDrago
1257 Views, 2 Replies
So - working with a client - they are working to get the revit server set up....
I can find it on wiki help. and some on youtube... But...
Is there any hard documentation about everything about revit server?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
2 REPLIES 2
loboarch
in reply to: LisaDrago
You can find documentation for Revit Server here.
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-354129A3-1F94-44A4-9B09-578AA7D4A497
Jeff Hanson
Principal Content Experience Designer
Revit Help |
LisaDrago
in reply to: loboarch
Thank you for the link.
That was one I was already using...
By hard documentation I was more referring to a print book.
While it is handy having it on the net... Having a book is very useful.
With that said I could see someone commenting - to print the help...
Already started doing that - well putting it in a word doc that can be printed.
Thanks again.
LD
