I am having trouble with a revit server 2013. The web admin does not seem to work. I have been looking through posts and in one of the images I notice you are accessing a data service. Cannot connect Revit Local Server - Autodesk Discussion Groups
I retraced these steps and this seems to be missing. My question is how do I get it in?
I checked this on the server and everything is there.
System Requirements for Revit Server - WikiHelp
your assistance would be most appreciated
Probably not the problem, but--
make sure MS Silverlight is installed at all locations.
Also try stopping and restarting RS service.
thank you for the advise but I am afraid that is not the problem.
Do you have any other suggestions?
Not really--but I'd check IIS and Web Service settings at the Server level on all servers in the pool.
Can you ping each server from each location?
Also check ip addresses / name resolution. ( i.e ip number - vs- server name. )
Try an ipconfig /flushdns and also ipconfig /renew.
I'm getting the same results as you. Were you able to resolve the issue? If so, what was your solution?
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
