Hi everyone, I'm a new revit user, and I'm having a problem with Revit 2011.
I have attached a photo of my wall cladding as an image for rendering. However, when I render, the color of the rendering is a whole lot lighter than the orignal photo. To get anything like the rendered color I want, I have to change the photo color so that it is really dark.
What am I doing wrong?
Lynnette Lane
Lynnette Lane CAD Draughting
Upper Hutt
New Zealand
When rendering, additional calculations are made to the material which fully take into the view lighting system and shader calculations for surface renderings. This often yields a brighter color than the simple shading color used for shaded or consistent views, but will vary depending on the view lighting or time of day currently in use. A darker color would occur, for example, for a later time of day.
You could adjust the resulting image values after the render completes using the exposure controls:
I have included a few additional resources below which I hope are helpful:
