Revit question
2 REPLIES 2
223 Views, 2 Replies
Revit question
I tried to open my REVIT 13 but appeared an error message (on 1st picture), then Autodesk send me an updating. I tried to install it but an other error message appeared (2nd picture). How could I proceed ?
2 REPLIES 2
Jason_S
Make sure you have the right update.
If you have Revit without a suite go here to download:
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9273944
If you have Revit Building Design Suite go here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20679039&linkID=16831210
Hope this helps you.
I've got Autodesk Revit 2013 and when I try to open it, appears this error
message pls see attached file.
I tried to use you suggested links below without any chance to solve my
problem.
Kind regards
Curzio
____________________________
Hello curziom8,
You have 1 update for your Autodesk Discussion Groups Subscriptions.
_____
Subscription to Topic: Revit question
-p/3930244> (1 Update)
There was a new Reply.
Subject:
Re: Revit question
p/3932024#M69191>
Author:
Caddman13 (Valued Mentor)
Date:
05-22-2013 04:34 AM
inkID=9273944> &id=2334435&linkID=9273944
inkID=16831210> &id=20679039&linkID=16831210
lithium.com?subject=Re:%20Revit%20question>
