ok. i guess we have no use to export these items and use the in AutoCAD or
ACA/ADT - just the building geometry and grids. if that stuff is in revit
already the final output will be from revit, not cad.
it depends on what you need the dwg for and how you plan to use it.
Brian Earsley
www.arete3.com
18645 South West Creek Drive
Tinley Park, Illinois 60477
708.342.1250 x.225
wrote in message news:5551219@discussion.autodesk.com...
"(4) Can we export any filles of rvt. format into autocad dwg format."
Yes. works great!
I don't know about working great. There are some things that don't always
export correctly. For example, arrow heads, text, hatches...there might be
more but it's by no means perfect, but it does work.
