Dear Officer,
I am a graduate student in Mechanical Engineering. But for my research need, I need a Revit file of a simple residential house (two floors, and no more than 8 rooms). I have been looking around on the internet, but not much information is available. I am wondering whether there is any place where I could download one, like some house examples made other people or by this community? My email is nyu@nd.edu.
Thanks so much!
Best,
Na
Solved by ennujozlagam. Go to Solution.
hi
Welcome to the Revit World.
I have a 2-storey residential house sample that i did few years back but not with 8 rooms. And I’m willing to share with you for your research.
Hope it helps. Wish you all the best and good luck.
I already send the files in your email add.
Hi! Thanks for your answer!
What kinds of key words should I put in Google Search to find the files you refered? Searching "Out of box samples Revit" does not give good results...
You will find all the default Revit sample files on your computer at this location:
C:\Program Files\Autodesk\Revit 2015\Samples (Replace the Revit 2015 with whatever version of Rvit you are using)
Hope this helps
Hi
could you please send me the file with two storey haus.
Respect
Massoud
Hi, Sobaat, i already send to your email account. hope it helps. thanks
hi, give me your email add. thanks
can_erdinc@hotmail.com
thank you!
im going to use this for a study to analize a buildings for energy efficiency. I have no idea how to build a house in Revit, so i need a really complete
designed Eco/green/zero emission/passive house and a normal house model in revit.
Maybe you can help me in that way,
best regards
Can
hi, already sent to your email add. please check. hope it helps. thanks
Hi I am also doing a research porject on BIM and i need to do an anlysis on a typical House model. Please could you send me the file aswell.
olivia.stapleton@btinternet.com
Thanks so much will be such a help as Ive got 1 week to finish the paper
Hi can you send the file to me too? I would really appreciate it!
dcfraz80@gmail.com
hi, already send to your email add. hope it helps. good luck, thanks
hi:
can you email me those files too at email:alimgarga2002@yahoo.fr. Thank you
@nyu wrote:Dear Officer,
Thanks so much!
Best,
Na
hi:
@tcheimegni, send already at your email add. good luck. hope it helps. thanks
