I am trying to draw framing plans (floor, wall, roof) for a house using Revit LT 2015. Can't figure out how to show the framing. Is this possible?
Please respond.
Thank you.
Thank you for your post. In this case you can modify the views to see the framing members but there is also an extension for the timber framing software. I have included a few links below, one for this extension to add in to your software, as well as the knowledge document on creating a framing elevation (among others). Please let us know in the community if this was helpful. Thank you.
Timber Framing Extension: https://apps.exchange.autodesk.com/RVT/en/Detail/Index?id=appstore.exchange.autodesk.com:timberframi...
Video of Wood Framing: https://www.youtube.com/watch?v=aKxaLdD0_6Y
About Framing Elevation Views: http://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU...
Revit Framing Enhancements for 2015: http://revitstructureblog.wordpress.com/2014/04/06/revit-2015-structural-framing-enhancements/
Is this the correct answer? Although the comparison between LT and Full Revit shows there is no support for third party apps, the Timber Framing app is an autodesk app. When I downloaded the Timber Framing app on a Revit 2015 LT machine, the extensions tab does not show? Most of the other replies on the forum say to create the members individually.
