Revit LT 2014. Solar Study
6 REPLIES 6
gccdesign
1603 Views, 6 Replies
In the comparison chart for Revit LT & Revit, is shows that Revit LT should do a solar study.
But it does not seem to be able to export an animation of a solar study.
The Export | Images & Animations then gives me a choice of Walkthrough and Image, but no solar study.
Am I missing something?
BTW, I'm just starting out trying Revit for a spin.
GChapp
6 REPLIES 6
luna.ye
in reply to: gccdesign
Hello gcCad,
You can export solar studies to a variety of file formats that can be easily distributed and viewed by colleagues and clients.
The export file types include JPEG, TIFF, TARGA, BMP, and PNG.
  1. Make sure the current active view has Shadows turned on.
  2. Click “R” – Export - Images and Animations - “Image”.
  3. Complete the options in the Export Image dialog as appropriate, and click OK.
Here’s an Autodesk® Revit®* 2014 vs. Autodesk® Revit LT™ 2014 comparison matrix. In the end of the pdf, it says “******Only still images are available for solar study export.”
Hope this helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Luna Ye
Product Support
gccdesign
in reply to: luna.ye
Ahh, the fine print.
I guess that answers that.
GChapp
will
Your answer is incomplete. Still images are fine for a solar study- but the point is how does Revit LT automate this? Do I have to adjust the sun settings for each still? Is there a way to simply run the export and capture all images in the specified time interval?
andriusQS4C2
Hi, Time is also not possible to input in Sun setting in Revit LT 2022 as it is stated here:
Define Sun Settings for a View | Revit LT 2019 | Autodesk Knowledge Network
in reply to: andriusQS4C2
You don't have this?
DarrenP
it shows up on mine
see screenshot
DarrenP
