I want to dimension to Core face exterior since thats how I drew the walls (core face exterior). It seams to be dimensioning to finish face exterior. Is there a setting a I need to change for dimensioning?
On the information bar there is a pull down menu that allows you to pick either wall centerlines, wall faces, center of core, faces of core. Select faces of core and hover over the face that you want and click then go on to the next.You can change the selection in the middle of dimensioning. ie I usually dimension to face of wall for exisitng walls and face of core for new walls.
