Revit Architecture
Revit Architecture
Active Contributor
bcarriere
Message 1 of 5 (773 Views)
Accepted Solution
Revit LT 2013 & Residential Framing
773 Views, 4 Replies
12-10-2012 08:46 AM
Has anyone completed a residential roof framing plan with Revit LT? If so, will you please share with me how you did it.
You can place individual instances of a beam (or other framing member) and then use the array command.
Active Contributor
bcarriere
Message 2 of 5 (739 Views)
Re: Revit LT 2013 & Residential Framing
12-11-2012 02:29 PM in reply to: bcarriere
OK, Anyone using Revit know how to do residential framing (floor & roof framing) in Revit LT?
Please note in Revit LT there is no "beam system" icon/option.
Employee
loboarch
Message 3 of 5 (718 Views)
12-12-2012 10:30 AM in reply to: bcarriere
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
Active Contributor
bcarriere
Message 4 of 5 (701 Views)
12-12-2012 05:28 PM in reply to: loboarch
Jeff,
Thanks for the reply! So, in this case, using Revit LT is no different than using AutoCAD (copy and/or array) with the exception that when the beams are arrayed they show up in all applicable views?
Valued Contributor
Irish2
Message 5 of 5 (693 Views)
12-12-2012 08:57 PM in reply to: bcarriere
Yes plus they are 3D. Move it in any view it changes in every instance. You can move the arrayed set or individually.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
