Revit LT 2013 & Residential Framing
4 REPLIES 4
bcarriere
1158 Views, 4 Replies
Has anyone completed a residential roof framing plan with Revit LT? If so, will you please share with me how you did it.
4 REPLIES 4
bcarriere
in reply to: bcarriere
OK, Anyone using Revit know how to do residential framing (floor & roof framing) in Revit LT?
Please note in Revit LT there is no "beam system" icon/option.
loboarch
You can place individual instances of a beam (or other framing member) and then use the array command.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
bcarriere
in reply to: loboarch
Jeff,
Thanks for the reply! So, in this case, using Revit LT is no different than using AutoCAD (copy and/or array) with the exception that when the beams are arrayed they show up in all applicable views?
Irish2
Yes plus they are 3D. Move it in any view it changes in every instance. You can move the arrayed set or individually.
