Revit Local Server administration page is dispalying.
3 REPLIES 3
helpdesk
476 Views, 3 Replies
We have 1 Revit Central Server and 5 Local Revit Server, Revit Central Server Administration page can open and we work. But all 5 Revit Local Server administration page is working and showing Revit Server is not available please check with administator or try again. It seems we need to check some access rights authontication and Autorization Rules in Revit Central server.  Any one can give hints to fix this problem. error file is attached
3 REPLIES 3
alan.quinn
in reply to: helpdesk
Sounds like you need to set up your RSN.ini file. However, make sure you review and follow all instruction in the following link.
http://wikihelp.autodesk.com/Revit/enu/Community/Links_and_Resources/Revit_Server_2013_Reference
You may need to start over on one of your locals to insure that you have everything installed correctly.
Thanks for posting.
helpdesk
Thanks for support.  Just I want to inform you that I am using Revit Server 2012, and administrator console is not working. When I log to Admin Console this message is  Revit Server is not available, please contact with administrator or try again later. It seems we need to configure in Revit Central Server IIS setting. Attached error file
alan.quinn
I'm assuming that this never works and if this is the case I would look at your setup to insure everything is in place. Please see the below link for more information.
Revit Server Administrator
http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_Administration_Guide/0002-Revit_Se2/0008-Revi...
Revit Server Troubleshooting
http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_Administration_Guide/0002-Revit_Se2/Revit_Ser...
Hope this helps and thank you.
