I received a linked revit drawing. The sender highlighted my walls the color blue in 3D mode.
I would like to diferentiate the wall colors even futher - i.e. red, green, etc...but how do I do this?
Solved by vector3. Go to Solution.
Go to Object Styles> Imported Objects. There you can change the
colors of the lines according to each layer.
