Our Architectural Dept. is having issues with getting REVIT Arch plans to look like AutoCAD Arch plans. Is there a way to import AutoCAD Arch lineweights into REVIT? We are using REVIT and AutoCAD 2011.
Bob
Solved by alan.quinn. Go to Solution.
Please review the information on the link:
Setting Line Weights for Imported DWG or DXF Files
http://docs.autodesk.com/REVIT/2011/ENU/filesUsersGuide/WS46b90c3cb2c58cad197a37cfc7f993a64-7fe4.htm
Or at the root of this search here:
Thank you for posting your question.
