I’m using revit 2012, if I zoom in and zoom out, some wall lines flicker and appear and disappear as I zoom in and zoom out. If I zoom at specific level it shows but at another level it doesn’t show. What is the problem?
Solved by parveen.revit. Go to Solution.
it's common graphic problem, but everything will print right.
you can check your graphic card acceleration, screen resolution etc.
well that did it, disabled the graphic acceleration in settings. but i don't understand i bought a new motherboard with integrated intel HD graphics, why did revit didn't recognize it? such problem is never been seen with any other software.
and i've disabled my graphic accleration, would i get a slow performance?
