Revit: Levels do not automatically show up in project browser
6 REPLIES 6
6972 Views, 6 Replies
Hi!
When we created a massing with floors, the levels did not show up in the project browser's plan view and ceiling plan views.
6 REPLIES 6
ennujozlagam
hi ,did you have created "black" levels instead of "blue levels" to make levels you have created show up in the project browser
Go to VIEW ribbon>on the CREATE panel look for PLAN VIEWS, click and select floor plans. Ensure "do not duplicate existing views' is ticked and select the levels you wish to make plan views of.
for future levels to show up in the browser without this process, tick the check box plan view in the options bar when making the level. hope it helps.
BalajiHTI
I think you need to create your Floor Plan and RCP views by yourself from the View Tab. Creating additional levels other than the preexisting ones in a Project template, will not automatically create the FP/RCP.
Hope this helps!
josemukalel
Go to View -Floor Plan - select the levels and click OKNew shortcut1.JPGNew shortcut2.JPG
Jose George
Architectural BIM/CAD Technician
josemukalel@gmail.com
+64 22513 0828
A KUDO is always welcomed; However, WHEN the above answer helps and/or clarifies your query; kindly mark it with ACCEPT AS SOLUTION
loboarch
Levels defined in the massing editor are NOT transferred into the project environment. Once the mass is loaded into the project the "Mass Floors" tool needs to be used to use the levels defined in the project as mass floors.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
in reply to: loboarch
I massed the floors, and created levels in the elevation... It still doesn't show up.  I'll try the above comment first, and I'll get back to you.
in reply to: ennujozlagam
Thank you. I found this the most helpful.
