Hi!
When we created a massing with floors, the levels did not show up in the project browser's plan view and ceiling plan views.
Solved by loboarch. Go to Solution.
Solved by josemukalel. Go to Solution.
Solved by BalajiHTI. Go to Solution.
Solved by ennujozlagam. Go to Solution.
hi ,did you have created "black" levels instead of "blue levels" to make levels you have created show up in the project browser
Go to VIEW ribbon>on the CREATE panel look for PLAN VIEWS, click and select floor plans. Ensure "do not duplicate existing views' is ticked and select the levels you wish to make plan views of.
for future levels to show up in the browser without this process, tick the check box plan view in the options bar when making the level. hope it helps.
Go to View -Floor Plan - select the levels and click OK
I massed the floors, and created levels in the elevation... It still doesn't show up. I'll try the above comment first, and I'll get back to you.
