Revit How to Lock an Level?
3 REPLIES 3
pfbelesa
2948 Views, 3 Replies
I m trying to sincronize some autocad data on Revit.
But as I finish the first level, i need to edit the second floor but
sometimes i select an level 1 wall. what i whant to know is how to LOCK the
level 1, it must be visible but not selectable.
Also , im trying to import multiple cad drawings to revit 1 to de level 1
other to level 2, how i assing with draw to wich level?
thaks
Paulo Fabio Belesa
www.pfb.eti.br
mobile: 27 9977-7269
3 REPLIES 3
in reply to: pfbelesa
How about, log in under a different name and lock that workset?
wrote in message news:4992298@discussion.autodesk.com...
thaks
Paulo Fabio Belesa
www.pfb.eti.br
Box select everything on Level 1 and do Pin Position. This will prevent these element from being moved, but you can still select
them. When you're done, you can select them all and Unpin Position.
If you really don't want to be able to select them, a workaround is to put them in a Design Option. Then they can't be selected
unless you uncheck "Exclude Options" in the option bar.
thaks
Paulo Fabio Belesa
www.pfb.eti.br
It depends on what you are talking about.
If this is a floor plan, then you probably have an underlay turned on. Turn
off the underlay and you won't then see or be able to select things on the
floor below. If you need to see the floor below as an underlay, then use a
window or crossing. Underlay objects below the current primary range are not
selected when using a window or crossing. They will be selectable however if
you just pick on them
If you are talking about 3D, then worksets are the way to go for separating
objects into different groups for selections.
"Irwin Jungreis" wrote in message
news:4992839@discussion.autodesk.com...
Paulo Fabio Belesa
www.pfb.eti.br
