You'll need to know the scale of the pattern as it was created in AutoCAD.
The preview doesn't scale the hatch to the size it will print - so you
couldn't use that as a guide anyway.
wrote in message news:5729638@discussion.autodesk.com...
To use custom fill pattern when we import the file using the Fill Patterns
dialog box how do we consider import scale because it's actually not visible
in actual model untill we finish this command. and also file unit is in
inches while I am in Metric environment. Please help.
