Revit Handover Received - SHARED PARAMETERS HELP
2 REPLIES 2
556 Views, 2 Replies
So me and my company have received a Revit file as part of a handover.
We've got full access to the data and are trying to edit a few things and I have a few questions:
- There are a number of SHARED parameters within the file
      - There is no shared parameter file - can i create one using the shared parameters already present?
      - Can I edit these shared parameters in any way? (Name, type of field to text from number for example)
Piestar
Using Autodesk Revit Architecture 2014
2 REPLIES 2
BIMgirl
You can export the shared parameters by selecting it and going to "Modify" > "Export" (either in a schedule or through the dialog box from the Manage panel).
I'm afraid you need to repeat this for each parameter, though there might be tools / apps out there which allow you bulk operations. (?)
The exported parameters will be stored in the shared parameters file selected under Manage > Shared Parameters, so it may be wise to create a clean one first before you start exporting.
The shared parameters are defined not only by the name, but also by a GUID stored in the Shared parameters file and in the project itself, therefore you must be careful when deleting / recreating them.
It's not possible to change a shared parameter after it has been created and added to a project, it may be easier to create a new one according to your needs!
Lejla Secerbegovic - Architect and Revit Expert
http://bim-me-up.com
in reply to: BIMgirl
Great help, thanks for the reply (Y)
