REVIT FEET AND INCHES
2 REPLIES 2
davie77uk
1824 Views, 2 Replies
I have a student version of revit 2014 and all my sizing, setting out and dimensions are comining in at feet and inches. I have found out how to convert this to mm but when I load in windows and doors, all the sizes of these are in feet and inches. Can anybody help me to change the door and window sizes to mm so that I know what size they are. Thanks
2 REPLIES 2
davidtetro
in reply to: davie77uk
Are the dimensions of the parameters in feet and inches or just the family type names?
SteveKStafford
Sounds like you really wanted to start with a metric template and library. There are options for both when Revit is installed. If you have the imperial library and templates you'll need to visit the Autodesk site to get the Metric content, there are different versions based on different regions. You have UK in your username so you probably want the Metric UK content?
My other older self here: http://forums.autodesk.com/t5/user/viewprofilepage/user-id/46056
Rail Community
