Revit fails on loading splash screen
4 REPLIES 4
cparsons
214 Views, 4 Replies
hi all,
we just loaded revit on one of our office laptops so one of our architects could work on it off hours. it fails when he tries to launch it wll the folllowing message:
"The application failed to inititalize properly (0xc0000005). Click OK to terminate to program."
*we have updated the video drivers to the latest version
*we have tried this with revit 8.0 and 8.1
*windows xp sp2
*dell inspiron 6000
I did a decent amount of google research and found a similar issue occurs with VIZ with some video cards. The fix there was to add an environment variable that would prevent the splash screen from launching. I was not able to find a similar fix for Revit.
Anyone seen this or solved it?
Chris
4 REPLIES 4
in reply to: cparsons
Have you turned off Hardware accelleration under windows display properties(not in revit, in windows)?
Try that first.
cparsons
An update.
We put Revit on two identical machines and it launched. Hardware Acceleration was enabled on both.
Autodesk suggests running Windows Update on the laptop to make sure all of the latest patches have been applied. The laptop is in Tahoe so when our remote user wakes up (he's on vacation) I'll ask him to run windows update and we'll see where we are.
Chris
did you try with hardware accel turned OFF? We have many machines that require it OFF in order to open revit.
cparsons
yes. the point of my e-mail was that it launches even when it is on.
