Solved by Alisder.Brown. Go to Solution.
You forgot the screenshot 😛
First thing to try, is to turn off your Anti-Virus and firewall. This can cause the install to fail.
How are you installing? Are you choosing the "Install Now" option? if so, try the "Download now" option or "browser download" If they all fail, good option is to get the media sent out to you. It is possible that there is a corrupt file in the download, so physical media is the solid option.
Could you attach the log file after the install fails, so we can see where it is failing.
cheers
