Revit Architecture
Member
0 Kudos
Post 1 of 6
Revit.exe-No Disk
1457 Views, 5 Replies
10-30-2012 11:47 AM
Running Revit Architecture 2012 - Student Version 64bit
Was running fine for some a few semesters, Then started to get this message and the Revit file would lock-Up
Revit.exe-No Disk
There is no Disk in the Drive. Please insert disk into drive\Device\Hard Disk\DR1
I have updated two of the Autodesk Revit Updates, Updated Windows, Ran a Anti-Virus.
It was working OK for a bit then again with the MESSAGE. I am not networking, or File sharing.
I did read a message that was posted last year, followed their direction and comments still locking up.
I did CADD Link files to REVIT, As this might have been an issue for the person posting last year.
Any direction on how to resolve this issue would be greatly appreciated
GR
Member
0 Kudos
Post 2 of 6
Re: Revit.exe-No Disk
11-05-2012 10:26 AM in reply to: gr8210774
TTT
Member
0 Kudos
Post 3 of 6
11-06-2012 10:17 AM in reply to: gr8210774
Product Support
35 Kudos
Post 4 of 6
11-06-2012 01:09 PM in reply to: gr8210774
It would appear your Windows setup probably registered a removable device as drive D at some stage (DR1 = drive C) and then later couldn't find it when it started up.
If you have not already, I would try the steps on the following page:
"There Is No Disk in the Drive. Please Insert a Disk into Drive \Device\harddisk\Dr1" Error Message ...
Chris Aquino
Knowledge Domain Expert
Customer Service & Support
The Revit Clinic
@Revitclinic
Member
0 Kudos
Post 5 of 6
11-06-2012 01:20 PM in reply to: gr8210774
894 Kudos
Post 6 of 6
Yes, this is almost certainly an issue with a removeable device.  You're going to have to put in the removable device and then change the drive letter.  It's the only way that I know of to fix this problem in Windows.
  • Log on to the computer as Administrator.
  • Insert a disk in the removable drive.
  • Click Start, right-click My Computer, and then click Manage.
  • Click Disk Management.
  • Right-click the partition, logical drive, or volume that you want to change, and then click Change Drive Letter and Paths.
  • Click the removable drive, click it, click Change, click the drive letter that you want to use, and then click OK.
