Revit Architecture
Revit Architecture
0 Kudos
Post 1 of 7
Revit doesn't use my gpu for rendering at all
1695 Views, 6 Replies
02-07-2013 02:27 AM
I have an intel 3570k cpu and an nvidia gtx 670 gpu, and it only uses my gpu for the 3d clview, but when it renders photos, it only uses my cpu, which makes rendering take so much longer. Is there any way around this?
i5 3570k@4.4ghz gtx 670, 8gb ddr3 1600mhz
85 Kudos
Post 2 of 7
Re: Revit doesn't use my gpu for rendering at all
02-07-2013 05:40 AM in reply to: kwikscopeguy
Revit uses a version of the Mental Ray render engine, which only uses the CPU for rendering.
This is because it is a raytrace rendering app.
3dsMax has the ability to use the GPU when you render with I-Ray.
Revit does not have this ability.
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
656 Kudos
Post 3 of 7
02-07-2013 06:41 AM in reply to: ccollins
you could also use the cloud rendering option
0 Kudos
Post 4 of 7
02-07-2013 06:48 AM in reply to: kwikscopeguy
I theare any way I could use a different engine for rendering, because I don't really lik the cloud rendering options
656 Kudos
Post 5 of 7
02-07-2013 06:49 AM in reply to: kwikscopeguy
not really without a third party add in if there are any for rendering in revit
0 Kudos
Post 6 of 7
02-07-2013 08:11 AM in reply to: DarrenP
I'll have to look around for one
Active Member
2 Kudos
Post 7 of 7
09-15-2014 03:32 PM in reply to: ccollins
Just in addition... if you are using 3ds for rendering with the GPU make sure you buy a Nvidia card, because it will use the Cuda Cores. Im purchased the ATI fire pro W5000 because the benchmark is higher than the QUADRO 4000, but 3DS does not uset the ATI for GPU render.
Also the same proble occurs with Octane Render.
Have fun rendering
