Revit Architecture
Valued Contributor
bbrown
Message 1 of 5 (593 Views)
Revit DB Link Error
593 Views, 4 Replies
12-14-2012 07:33 AM
I am getting an error when exporting my Revit project to Access 2010. I am only getting this error on this file, the utility works on other files. Any help would be appreciated.
Try reviewing the journal recorded by Revit for more information on the error.
The following document has information on the location of the journal files:
Location of journal files
http://usa.autodesk.com/getdoc/id=TS1067426
The following blog posts have information on reading journal files:
http://revitclinic.typepad.com/my_weblog/2009/03/a-journal-file-story-part-1.html
http://revitclinic.typepad.com/my_weblog/2009/03/a-journal-file-story-part-2.html
http://revitclinic.typepad.com/my_weblog/2009/03/a-journal-file-story-part-3.html
http://revitclinic.typepad.com/my_weblog/2009/03/a-journal-file-story-part-4.html
Valued Contributor
bbrown
Message 2 of 5 (584 Views)
Re: Revit DB Link Error
12-14-2012 08:05 AM in reply to: bbrown
I have also tried setting up a DSN to Access through ODBC and I get a different error now, but it appears to be from the same thing. From this error it appears that Revit is trying to put values into columns that have a fixed size and the values are too large. The trouble is I can't figure out what these values are.
Product Support
Lance.Coffey
Message 3 of 5 (537 Views)
12-18-2012 11:25 AM in reply to: bbrown
Lance Coffey
Valued Contributor
bbrown
Message 4 of 5 (533 Views)
12-18-2012 12:13 PM in reply to: Lance.Coffey
Here is the journal file. The program freezes without throwing the error in the journal. I am going to try deleting Generic families to see if that helps.
Valued Contributor
bbrown
Message 5 of 5 (526 Views)
12-18-2012 01:34 PM in reply to: bbrown
I deleted the Windows families ( a louver) and it worked. It took it 25 minutes to export the database and showed in Windows as not responding the entire time.
