Revit crashes when I draw a line
4 REPLIES 4
946 Views, 4 Replies
I am a high school drafting teacher and have Revit 2012 installed on the student computers. The computers are only a year old.  However, they do have integrated video.  The computers are capable of running Inventor 2012 with not problems at all.  The problem that I have having is that when I try to draw a wall on Revit, a message pops up that says "An error has occurred while drawing the contents of this window. This window shall be closed."  It only happens when I draw a wall in LINE form.  If I use the rectangle tool to draw all 4 walls at the same time, it doesnt crash.  HELP!
Tags (2)
4 REPLIES 4
loboarch
This message typically happens when there is a problem with the graphics card/driver on the PC.  You can try turning off hardwarfe acceleration in the Options menu (found on the big purple "R").  This may help with the situation.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
salemabdalla
in reply to: loboarch
Hello, I'm a new user. I've got the same message when I draw a wall. I tried  turning off hardwarfe acceleration in the Options menu but Revit still crashes on me.
Salem
Salem B. Abdalla
Architecture Engineering Department
College of Engineering
Sharjah University
Sharjah, PO Box 27272, UAE
Tel: +971-6-5050814
e-mail: sabdalla@sharjah.ac.ae
qtarchitect
It happened to me too.
I did turn off the graphic acclleration om the Option Menu at the upperleft R icon.
I reloaded, repaired and reinstalled to no avail.
Please help, we are having a class here with 2 students and the instructor seems to be in desperate mode.
qtarchitect
in reply to: qtarchitect
It works now, I follow Jeff Hansen's post:
just remember to x out the program and reopen it for the change to be affective.
Thank you Jeff.
