Every time I press the start button (the nice big R) Revit crashes like this:
http://www.youtube.com/watch?v=-CuY03L_mj4&feature=youtu.be
It takes about 30 seconds before I can go further.
Are there any solutions to fixing this?
Thanks!
P.S..
I use Revit 2013 Student version
CPU: i5-2410M @ 2,30GHz
GPU: Nvidea GT560M (or something)
6GB Ram
Windows 7
Solved by ryan.duell. Go to Solution.
Try #3 in the link below:
http://revitclinic.typepad.com/my_weblog/2009/10/troubleshooting-startup-delays.html
For Revit 2013, for example, the Revit.ini is stored:
C:\Users\%username%\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2013
Thanks for your answer. I have opened revit.ini and I found a lot of old 'recent' files that where long gone and deleted. I deleted those out of the list and it seems to have helped cause revit starts up nicely and the button is working properly again.
