Hi all,
I can't find any info on this, just over the last week one of our users has been experiencing a problem where Revit closes suddenly, for example she inserts a family. Revit just kept closing on her this morning when she'd try opening it, so I opened application manager to double check updates and there's a blue box at the bottom that says 'host not found'. I think it's a licensing thing? We are all on stand alone licenses though. Any ideas? Thanks
Is your problem resolved?
I would suggest try to run repair from the add or remove program. Probably it will fix the problem.
I hope this helps.
@Anonymous hello just for info "Application Manager is being replaced by the Autodesk desktop app" since march 2016. you can try to check it HERE. hope it helps. thanks
