Revit Architecture
Revit Architecture
0 Kudos
Post 1 of 3
Revit Configuration File
357 Views, 2 Replies
01-15-2004 11:52 AM
Greetings,
Just got Revit 5.1L (havent rolled out 6 yet). Ideally, I would like to configure 1 PC to use certain options (drive mappings to support files, etc). Is there a config file for revit that if I copy it to other PC's the mappings to the libraries on the network will be already mapped?
Thanks!
*Greg Cashen
Post 2 of 3
Re: Revit Configuration File
01-15-2004 12:01 PM in reply to: jwolfer
look at the revit.ini file in the program directory "jwolfer" wrote in message news:32344393.1074196462929.JavaMail.jive@jiveforum2.autodesk.com... > Greetings, > > Just got Revit 5.1L (havent rolled out 6 yet). Ideally, I would like to configure 1 PC to use certain options (drive mappings to support files, etc). Is there a config file for revit that if I copy it to other PC's the mappings to the libraries on the network will be already mapped? > > Thanks!
Distinguished Contributor
0 Kudos
Post 3 of 3
01-21-2004 08:57 AM in reply to: jwolfer
REVIT.INI file
