We are using Revit Architecture 2013.
We are working on a big project with Revit and using many linked Revit files, within each other. Everything works fine while using Revit but we need to export all our files to Autocad for other diciplines. While exporting a view with a linked file in, Revit erases parts of the walls of the linked file if there is another wall on the view that is touching the wall. We have our structural walls on the linked file so we need to have the walls one piece on Autocad.
Please see the attached image for clearance.
How can we export a view fully with linked file?
Is there a draw order between the objects on the view and the objects of the linked file, or between different linked files on a view? We have also tried underlay option of the linked file, but it created other problems (in some files the linked file is totally gone, and in some files the detail items of the linked view is gone, etc.).
