Revit Central Model Computer Incompatibility
1 REPLY 1
jsworks
353 Views, 1 Reply
I created a central model Revit 2013 file in my revit class computer. Saved it to my flash drive to continue working on it at home. But the file would only open as a "not-editable" file.
1. When I saved the file, the not-editable option was the only option available. Editable was grayed-out.
2. When opening on my home computer, the message I received was essentially to save-as under a different user name. When I tried that, I received another message saying that the file could not be saved. Also, I saw no detach file option on my home computer.
3. My class computer and home computer have different log-ins (obviously). I figure that computers that are not networked, or have different log-ins, will make a central model file created in one computer, not editable in the other.
Does anyone have alternate steps that one can take to solve this "not-editable" problem?
Thanks, Jim
1 REPLY 1
fernanda.firman
in reply to: jsworks
Thank you for visiting our blog.
Please make sure you follow the steps suggested on the follow link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13126225&linkID=21208795
Hope that helps.
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
