Thanks for quick answer Steve.
I had no serious problems with Save To Central yet, but I'll keep it in
mind. I hope next fixing release will improve site modeling stability too.
Damir
wrote in message news:4878831@discussion.autodesk.com...
Revit support tells us that there is a Save To Central issue with the
current build. If you are experiencing crashing while Saving To Cental then
they advise installing the previous build. A fix is expected soon.
To install the old build you must first remove the new build, using Windows
Add/Remove Programs feature.
