I am looking to know if there is a 3rd party plugin / add-in (or if autodesk do it) which will do the following:
I have seen and tried a number of add-ins on the autodesk exchange and all fall short, even the autodesk add-in for batch plotting.
This is a large gap which autodesk has built within Revit and should be sorted sooner rather than later as its is out there for other platforms and consumes a large amount of time and effort if having to print multiple time....
Thanks.
Here are some Apps I found that should work for you:
1. SOFiSTiK 3D-PDF Export 2014 (64-Bit) .RVT to .PDF
2. RVT Xporter - .PDF to .DWG
3. CTC BIM Project Suite 2014 - Custom Naming
I hope this helps with what you are looking for.
Hi Scott,
I have looked at RVT exporter before and the batch plot function is similar to Revit in regards to different paper sizes, so doesn't work for me.
I have actually discovered Xrev Transmit which does everything I need.
Miguel
