Revit Architecture
Active Member
bobmayflower
Message 1 of 46 (6,623 Views)
Revit Backwards Compatibility
6623 Views, 45 Replies
01-11-2012 07:21 AM
Does anyone know what Autodesk plans to do about the backwards compatibility issue with Revit?  I have Revit 2012 but I have to use Revit 2011 because the software is incapable of saving back a release.  This is total craziness!  Why would anyone knowingly upgrade with this being the case?
Hi Jeff,
I appreciate everyone’s comments.  From my perspective it seems that there is a huge opportunity for future versions of Revit in the area of specialty equipment.  Only in the past few years has Revit even come on the radar of foodservice equipment manufacturers, (keep in mind this is AutoCAD, Inventor, Pro-E, and SolidWorks territory not Architectural).
My advice to Autodesk:
I would look at the possibility of creating either a more robust family editor, or maybe even a hybrid product that’s a cross between Inventor and Revit.
Look at the size of the foodservice industry alone, the number of companies involved, and you may agree that there’s an opportunity here.  On the kitchen design side there are still a large majority using 2D AutoCAD.  Look for ways to tear down the barriers that keep users out of latest version Revit.  I hope you will find some of this helpful.
Employee
davissc
Message 2 of 46 (6,608 Views)
Re: Revit Backwards Compatibility
01-11-2012 09:44 AM in reply to: bobmayflower
There are no plans to make Revit backwards compatible.  Why would you not upgrade to 2012?  If its consultants, why would they not upgrade?  It's total craziness to NOT be using the latest release.  2013 products are coming soon...then you will be 2 releases behind.
Scott D Davis
AEC Technical Specialist
North American Sales
Want Revit Content? Go to http://seek.autodesk.com !
Active Member
bobmayflower
Message 3 of 46 (6,591 Views)
01-11-2012 03:09 PM in reply to: davissc
Hi Scott,
That’s a very easy question to answer.  If I create a family in Revit 2011, it’s possible to use that family in Revit 2011, 2012, and so on.  If I create that same family in Revit 2013, only those who have that release can use it.  In order to stay compatible with the widest audience I have to work in an order version of the software.  Speaking for myself, I don’t know anyone working in 2012, and even if I did I would still be compatible working in 2011.  Clearly Autodesk has no clue how users really use the software.
This is a big problem!  I would like to see Revit become the standard for architectural design, but there needs to be a way to save files down a version.
Employee
davissc
Message 4 of 46 (6,582 Views)
01-11-2012 05:14 PM in reply to: bobmayflower
Revit has been around for nearly 12 years now, and in north America, is the architectural standard.  Most users are on 2012, and if you aren't, well you are nearly a year behind and its time to upgrade.  If you really need to make families that are available across multiple versions, then simply build them in an earlier version.  I used to do it all the time when I was in arcitectural practice.  Autodesk is well aware of how its customers use its products.  Through the Customer Involvement Program, we even know what commands you use most often.
What it comes down to is communication:  communicate with your project teams, including consultants, and decide collectively what versions will be used for the life of the project.  Or decide collectively when you will upgrade.  On subscription, you can use up to 3 versions of Revit.  On subscription, you have immediate access to upgrades.  There really is no good reason why anyone should continue to use an older version.  Sorry, this isn't intended to come across as harsh, but its reality.  My job puts me in front of customers every day so I have experience in this subject.
Scott D Davis
Active Member
bobmayflower
Message 5 of 46 (6,563 Views)
01-12-2012 07:50 AM in reply to: davissc
Hi Scott,
It appears we are talking about 2 different things, maybe because I’m not being clear enough on the situation.  First off, if you read my original post, I do have the latest version of Revit.  Second, I’m talking about family creation not projects.  If I create a family in Revit 2012 it can only be used in a Revit 2012 project which is a limitation.  But if I create the same family in Revit 2011 it can be used in Revit 2011, or 2012.  I want the families I create to reach the broadest audience.  I don’t think you understand the situation I’m in.  If I’m creating families in the latest version I can’t save down a version, I have to re-create the family from scratch in an older version.  This costs me money.
New Member
eframpton
Message 6 of 46 (6,542 Views)
01-12-2012 10:47 AM in reply to: bobmayflower
This is how Autodesk forces people to buy the latest release.  Total craziness......
Employee
davissc
Message 7 of 46 (6,537 Views)
01-12-2012 10:56 AM in reply to: eframpton
Forces you to buy?  Most likely you are on subscription so new releases are yours already.  But besides that....no pressure.  If you want to continue using older versions with less performance and less functionality, thats your choice.
Scott D Davis
LisaDrago
Message 8 of 46 (6,536 Views)
01-12-2012 10:57 AM in reply to: bobmayflower
A side thought... If you are on subscription with Autodesk - you do get previous version use. Since you have 2012 you can use 2011, 2010 and 2009. So if you needed to start your familyson 2009 and then use them in any version after.
For project work - it is a best practice I discuss with cllients that what ever version you start a project in - you finish it that same version. This avoids any issues with team members/consultants not wanting or having the finances to upgrade the software.
just my $0.02
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
rosskirby
Message 9 of 46 (6,530 Views)
01-12-2012 11:53 AM in reply to: bobmayflower
My guess is that the OP represents a manufacturer of some sort, and is not actually in the architectural profession, so telling him to coordinate with the project team prior to starting probably isn't going to get him very far.  However, if you look at most of the manufacturer's out there, they tend to release their families in only the latest release, or at most, the current release and one prior release.  Since a vast majority of Revit users upgrade with each new release, having to provide content in prior releases just shouldn't be that much of an issue.
Personally, I'd rather have every manufacturer's family in the latest release; that way I don't have to sit through the "upgrading family" whenever I load it the first time.
My advice to the OP: build your families in the current release.  Upgrade your entire library of families with each new release, but keep a copy of the older versions for at least 2 releases, in the event that some functionality is lost from one release to another (e.g. family painting parameter disappearing between 2011 and 2012).
Ross Kirby
BIM Manager
Arcturis
Active Member
bobmayflower
Message 10 of 46 (6,517 Views)
01-12-2012 04:08 PM in reply to: rosskirby
Your guess is pretty close.  I work with foodservice equipment manufacturers and commercial kitchen designers.  No one I work with uses Revit 2012.  I have a subscription as well as the latest version of Revit.  I created this post mainly to see if Autodesk has any intension to allow a user to save a Revit family back a revision or two.  According to Autodesk Scott, the answer is simply no.
I very much want to work in the latest version of Revit, but I cannot simply because the software does not have the capability of saving to a previous version.  Because of that limitation I’m forced to do all my work in an older version.
In my opinion, bottom line, if Revit could save families back a release or two it would give kitchen designers a reason to upgrade.  I also think it might give kitchen designers using AutoCAD incentive to try Revit.  If I were Autodesk I would listen to my customers, look for every opportunity, and not be so dismissive.
