Can someone clarify if there is any functioning difference between the revit.exe program included with Revit Design Suite and one that comes with Revit Architecture?
I downloaded my "Design Suite" upgrade today and now have 2 versions of Revit 2013 running - which is the best one to keep?
Cheers
Solved by philip.s. Go to Solution.
Hello roothcad,
Check out this Revit 2013 Comparison Matrix for specifics, which details Revit, Revit Architecture, Revit MEP, and Revit Structure.
Please accept as a solution if this fully resolves your inquiry, or reply with additional specifics as needed.
