Heres another one for you - we have built adminimages for Revit 2015 from the BDSP download with the automatic update feature disabled (as we like to manage the download / install process for our typical 700+ installs of Revit per version). The build of Revit from the BDSP package is again: 20140223_1515(x64), without having the application manager installed how can i get the UR1 patch downloaded as it doesnt appear on the http://knowledge.autodesk.com/support/revit-products/downloads site where i would expect to find UR's?
Many thanks,
Nick B
There's been a delay in the posting of UR1 to the Autodesk website but you can still access the installers from these links:
http://download.autodesk.com/SWDLDDLM/Updates/RAC/R3/x86/RLT2015UR1.exe
http://download.autodesk.com/SWDLDDLM/Updates/RAC/R3/RAC2015UR1.exe
http://download.autodesk.com/SWDLDDLM/Updates/RAC/R3/RLT2015UR1.exe
http://download.autodesk.com/SWDLDDLM/Updates/RAC/R3/RME2015UR1.exe
http://download.autodesk.com/SWDLDDLM/Updates/RAC/R3/RST2015UR1.exe
http://download.autodesk.com/SWDLDDLM/Updates/RAC/R3/RVT2015UR1.exe
Tony Michniewicz
Autodesk Revit QA
Hi Tony,
i dont suppose you have the DL links for Revit 2015 UR2 that has also been released? again it seems that its hitting App Managerbefore the knowledge sites again.
thanks in advance,
Nick B
Hi Nick
I just so happened to have those links and here they are:
http://download.autodesk.com/SWDLDDLM/Updates/2015/RVT/Autodesk_Revit_2015-x64_Update2.exe
http://download.autodesk.com/SWDLDDLM/Updates/2015/RAC/Autodesk_Revit_Architecture_2015-x64_Update2....
http://download.autodesk.com/SWDLDDLM/Updates/2015/RME/Autodesk_Revit_MEP_2015-x64_Update2.exe
http://download.autodesk.com/SWDLDDLM/Updates/2015/RST/Autodesk_Revit_Structure_2015-x64_Update2.exe
http://download.autodesk.com/SWDLDDLM/Updates/2015/RLT/x64/Autodesk_Revit_LT_2015-x64_Update2.exe
http://download.autodesk.com/SWDLDDLM/Updates/2015/RLT/x86/Autodesk_Revit_LT_2015-x86_Update2.exe
Hope that helps!!
Tony Michniewicz
Autodesk Revit QA
Yeah, that is an odditiy that has been around for a while. In this context, the original release of Revit is considered Version 1 so UR1 ends up being Version 2 and so on.
Also, Revit patches are cumulative so UR2 contains all of the updates from UR1. For this reason, you only need to include the latest service pack when creating a deployment.
Tony Michniewicz
Autodesk Revit QA
My files can't be uploadeds in cloud, i tryed meny files and more than one user account. i just could render it at other machines, does any one konws something about my network or my OS that can be causing this problem?
thanks.
