I spent all day yesterday downloading the 4 parts that I need to run my premium design suite version and after all 4 parts downloaded and I try and intsall them it claims all 4 files are corrupt and I can't do anything with them.. Any ideas?!
Hi Kate,
These types of errors can typically be resolved by taking the following steps:
- Change your download method
- Clear the cookies and cache from your preferred web browser
- Temporarily disarm your firewalls or antivirus software
If the error persists please respond to this post with your installation log. Or please "Accept as a Solution" if this post resolves your issue so that others with this same question can more easily find an answer. Thank you!
Attached is what is in my %temp% folder after trying to install Revit
Hi Kate,
Could you open the RevitCustom.log or the cp_Install.log so I can see the actual installation log? Also, did you try the steps that I listed above?
For sure, the first 3 parts of the Suite need to be about 4 GB in size (3.9). If it's not that size, it will NOT work.
