Revit architecture 2013-rpc shrubs not showing
3 REPLIES 3
simonlee
1099 Views, 3 Replies
I seem to be having a problem with my shrubs inserted from the internal planting library, in plan view when placed on the screen, they show as they should but in elevation view they show as squares and in 3d show as shaded cubes.
Is this a problem with the software or have I inadvertently done something I shouldn't have?
Simon
3 REPLIES 3
Chris.Aquino
in reply to: simonlee
It may help to troubleshoot if you can post a screenshot of what you are seeing along with the family file.
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
cosstroe
in reply to: Chris.Aquino
I  have the same problem with RPC in Revit 2013.
In Revit 2012 I had no problems, but in Revit 2013 a lot of.....one is this with RPC..
In the attached video you can see what's happens when I try to edit the RPC ,in the first case the program is blocked, in the second shows error and kick me out...
simonlee
in reply to: cosstroe
That is the problem, although I have 'repaired' the revit 2013 install and it seems to have sorted the problem for new projects but not for existing ones.
