Is there a general consensus regarding the interoperability enhancements in Revit Architecture 2013? How well does it integrate MicroStation? Are there any settings that make this integration work better?
The only improvement that I know of is now when you import
dwg lines, Revit won't tell you most of those lines are useless
and off axis. Because now Revit will move those line into a
precise Revit position automatically. But I haven't found that
to be worth much. And I don't find the notion of "interoperability"
to be worth much either. You look at drawings from some
other program and you start a Revit project from them. If there
are dimensions on those other drawings, then you can start
your Revit model that much quicker.
All new enhancements for 2013 can be found in this page:
