Revit Architecture 2013 frquent fatal errors
4 REPLIES 4
timandjo
2995 Views, 4 Replies
I am having very frequent recoverable errors - havent seen any pattern but happens in veiws and mostly editing operations. I am filling in the error reports and there must be quite a collection now of mine. Anyone else having the same - update pack needed and when?
4 REPLIES 4
LisaDrago
in reply to: timandjo
What kind of errors is it saying?
Are you on subscription? If so - open up a support ticket directly with Autodesk. If not contact your reseller to do this.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Chris.Aquino
After looking through the Error Reports that were submitted, it looks like the issue is related to a conflict between Revit and the graphics hardware or software on the machine.
I would make sure that your graphics card and driver are on the tested and supported list below. I would also try disabling Hardware Acceleration to see if the behavior changes.
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
I also see you are saving to a drive "H:". Is this a local drive (or partition) or a networked location?
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
timandjo
in reply to: Chris.Aquino
Thanks for looking into the error reports I updated recently to the latest NVIDEA driver - I know it is later that the autodesk recommended - will roll back to this and see if it works. Seems the frequent crashes started after update - hadn't connected the two until now. H drive is local and a separate drive - ( 2 SATA (not in RAID array) with drive naming legacy from previous use). Regards David Cormack
Reg.E.Allen
I am also having very frequent fatal errors, is it possible for you to have a look at the error reports that i have been submitting this afternoon.
we have just installed revit 2013 on new Dell Percision T1650 computes, with 16.0GB of ram. with a 64 bit system.
but since its been installed it has crashed more in 2 days that the whole time we had revit 2012 on old computers that weren't near as powerful.
Any ideas as to what is causing this problem.
Regards
Alice
Rail Community
