Revit Architecture
Revit Architecture
Active Contributor
1 Kudo
Post 1 of 3
Revit Architecture 2013 decal settings won't stick
453 Views, 2 Replies
02-12-2013 04:38 PM
I can change the Decal Types settings in Revit Arch 2011 but not 2013.  I looks like I can change them but if I click OK and then open the Decal Types dialog box again to check the settings are back to default.  I'm trying to change the Finish and Luminance.  I tried it in several files with the same images (png and jpg) but it only works in 2011.
Active Contributor
1 Kudo
Post 2 of 3
Re: Revit Architecture 2013 decal settings won't stick
02-25-2013 10:35 AM in reply to: trucdang3750
Update
I filled out a trouble ticket with AutoDesk.  The Development team indicated that there needs to be a code fix, however they did not provide a time frame or a work around.  I will keep you posted.
New Member
0 Kudos
Post 3 of 3
05-16-2014 03:09 PM in reply to: trucdang3750
I am also having the same problem with Revit 2013, but was not an issue with 2011.  I try to change the luminosity setting, but the settings don't save.  Any update on a possible fix?
Shawn
