Revit Architecture 2013 Closes immediately after splash screen
1 REPLY 1
freakyword
1454 Views, 1 Reply
Hi, this problem have been harrassing me for years, not just in Revit Architecture, but also in AutoCAD...Sometimes I fixed it somehow, and later after a couple months it showed up again.
I used Revit Architecture 2013 student version. The program disappears after it loads into the screen where it asks you to open project or create a new one. Could you help me figure out this problem? Thank you. I don't know why this problem has happened to me on each one of my laptops..
Thank you!!
1 REPLY 1
LisaDrago
in reply to: freakyword
Have you tried doing an clean un-install and reinstall of the software? you probably  have but need to start somewhere..
This link will explain how to do the un-install:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18782231&linkID=9243099
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
