Revit Architecture 2012 install problem windows 8
5 REPLIES 5
2201 Views, 5 Replies
I am trying to downlad Revit architectur 2012 for windows 8, and am having some problems. It downloads to my computer, but as it is installing, it says 3 things failed to download. Thoes three things are the only 3 that need to download. Has anyone else had this problem?
5 REPLIES 5
Jason_S
I would look here for the latest info on products being able to run on windows 8.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19048377&linkID=9240617
I have Revit 2012 and Revit 2013 running on at least 10 computers and counting with Windows 8.
How are you downloading it and running the install?  Are you sure the download doesn't time out before completing?
in reply to: Jason_S
I'm downloading it through the browser. I am using google chrome. Sent from my iPhone
Jason_S
I download it (using IE10) by doing a browser download and saving to it to the local desktop. Then run the installer, which wants to extract all the data to a place somewhere on the computer.  I create a folder and place the extracted data there.  Then I run the Setup.exe from there.
I have not tried the Google download method.  I will try that over the weekend to see if or how it differs from IE10 on Windows 8.
Okay ill try that and see what happens Sent from my iPhone
emmanuel
I can't seem to find the post thread to thank the person who posted it; while Revit 2012 and 2013 are not supported on Wndows 8, the solution for me seemed to be to enable the .Net Framework 3.5 in windows 8.  I tried Revit 2012, 2013 and 2014 and they all failed until I enabled the .Net Framework.  I have a lot of projects in 2012 and a client who insists on 2012 so it was critical to me to get that working, otherwise I would have had to reformat my laptop to Windows 8 to reinstall verson 2012.
