Below is the image of my ribbon after I begin the edit boundary command for a floor slab. For some reason the ability to finish or cancel the edit mode disappears and I'm unable to close out of the command without undoing everything I've done. Has anyone else expereienced this? and if so is there a solution? Thanks
Chris
I had the same problem today and discovered that when I double-clicked the "Modify" tab (it may take more than 2 clicks), the "finish sketch" suddenly appeared!
I just experienced this in Revit 14.
I found that by typing in a hot-key shortcut...DI for instance to put a linear dimension down...REVIT would bring the ribbon command back up associated with that command. Then when escaping off that window, the ribbon for the boundary lines would reappear.
Unfortunately not, I have to complete a plan made in 2012 and that's frustrating !! Have to play with the ribbon.
Double click on modify/floor.......
