Revit Architecture
Revit Architecture
Member
archytextural
Message 1 of 25 (5,358 Views)
Revit Architecture 2012 edit boundary ribbon issue
5358 Views, 24 Replies
02-13-2012 01:05 PM
Below is the image of my ribbon after I begin the edit boundary command for a floor slab. For some reason the ability to finish or cancel the edit mode disappears and I'm unable to close out of the command without undoing everything I've done. Has anyone else expereienced this? and if so is there a solution? Thanks
Chris
There is finally a fix for the issue.
Hotfix - Autodesk Revit 2012 - Ribbon behavior due to .Net 4.5 installation
Mark.
ccollins
Message 2 of 25 (5,354 Views)
Re: Revit Architecture 2012 edit boundary ribbon issue
02-13-2012 01:16 PM in reply to: archytextural
On a workset enabled project, try saving locally ( the black save button at upper right part of screen.)
This will sometimes restore the Finish Sketch dialog box.
Also, try View>User Interface and check/uncheck/check all of the boxes to "refresh" the UI.
cheers
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
Member
archytextural
Message 3 of 25 (5,352 Views)
02-13-2012 01:17 PM in reply to: ccollins
thanks, next time it happens I'll give that a try. Cheers!
ccollins
Message 4 of 25 (5,349 Views)
02-13-2012 01:23 PM in reply to: archytextural
Did it work? ( did the finish sketch box come back?)
Cliff B. Collins
St. Louis, MO
Member
archytextural
Message 5 of 25 (5,347 Views)
02-13-2012 01:24 PM in reply to: ccollins
I had shut down revit and restarted, so I'll have to wait for the error to occur again before trying.
New Member
Jenni722
Message 6 of 25 (5,285 Views)
02-24-2012 08:33 AM in reply to: archytextural
I'm having a similar issue with one install of Revit 2012. Here is the process:
1: Create a floor (for instance).
2: Create something else, or press Escape a couple times.
3: Select the floor object.
4: The Modify ribbon tab should change to show the "Edit Boundary" button, but instead is still showing the tools for creating lines:
Whatever I do in Revit, the Modify tab shows the previous state, not the current tool I need. It affects all users on this machine. Ribbon has been reset via VBS script, Revit has been uninstalled/reinstalled, Quadro drivers have been changed, updated, rolledback, and Direct3D acceleration has been turned off and on. Nothing has gotten the Modify tab to work properly.
I can either cycle the ribbon state (from full to tabs, for instance) and the menu is then correct, albeit a different size. I can then keep cycling the menus to refresh the Modify tab, or I can Ctrl-left-click drag the tab to another position, and the correct menu appears.
Very frustrating and impacts productivity. Anyone else have this, or am I the only person on the planet? All other Autodesk apps work perfectly fine, the only issue is with Revit.
Jenni
New Member
userl
Message 7 of 25 (5,261 Views)
02-26-2012 07:54 AM in reply to: Jenni722
Jenni, I have just the same problem. Sadly still no idea how to fix it. I try to reinstall too. Installed SP2 and still no change. It is very time consuming to close and open ribbon every time you change your tools. If anyone know solution please share it.
Member
archytextural
Message 8 of 25 (5,179 Views)
03-21-2012 11:33 AM in reply to: archytextural
the UI check box thingy worked the best so far, but still not a good solution.
New Member
wesil
Message 9 of 25 (5,166 Views)
03-21-2012 03:56 PM in reply to: archytextural
same problem here has been happening since 2008. very annoying UI works better than shutting down at least..........
Valued Contributor
regalith
Message 10 of 25 (4,712 Views)
Re: Revit Architecture 2012-2013 edit boundary ribbon issue
10-05-2012 11:07 AM in reply to: archytextural
I was disappointed to find that 2013 has the same problem.  I have to minimize and show ribbon to refresh the content specific buttons.  Anyone have a solution?
