Revit Architecture 2012 crashing with clr.dll error
6 REPLIES 6
rkotsybar
2270 Views, 6 Replies
Revit Archituecture 2012 installed with updates 1 and 2. Issue with program crashing on startup. Workstation is bound to a domain, with domain user given local rights on machine. Issue can be fixed by rebuilding user's profile, but problem reappears after a few days of use. Roaming profile turned off for the user. Windows 7x64
Error generated from Revit....
Problem signature:
Problem Event Name: APPCRASH
Application Name: Revit.exe
Application Version: 2012.0.2011.916
Application Timestamp: 4e740905
Fault Module Name: clr.dll
Fault Module Version: 4.0.30319.544
Fault Module Timestamp: 4ee99e7c
Exception Code: c0000090
Exception Offset: 000000000014aba9
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 9cdd
Additional Information 2: 9cdd92247ac082e368b6789a339c11d5
Additional Information 3: 182d
Additional Information 4: 182d63014f92fffc18142c493689b2ff
Additional events generated in events viewer....
.NET Runtime version 4.0.30319.544 - Loading profiler failed. COR_PROFILER is set to an invalid CLSID: 'Revit.BorderSentinel'. HRESULT: 0x800401f3. Process ID (decimal): 4604. Message ID: [0x2502].
and
Faulting application name: Revit.exe, version: 2012.0.2011.916, time stamp: 0x4e740905
Faulting module name: clr.dll, version: 4.0.30319.544, time stamp: 0x4ee99e7c
Exception code: 0xc0000090
I have tried the KB hotfix for the clr.dll file, and repairing .NET 4.0 but still no luck.
ANy ideas?
Thanks in advance.
Rob
6 REPLIES 6
Manlight
in reply to: rkotsybar
Hello, I have the same problem.
Do you have solv it?
yavork
Few years later the problem has returned - since begining of the week older versions of revit (2014, 2015) are having issues with this. Repairing .net doesnt work, now waiting for Autodesk remote session to see what is going on...
MarkMoorhead
in reply to: yavork
Same problem here.  If you get a solution from AutoDesk, please update.
Good Luck!
yavork
in reply to: MarkMoorhead
Autodesk support was uselles - just the ussual install reinstall, repair etc... Turns out was one of the add-ins. After updating it now works fine. I found that by renaming the plugins folder for my version located here C:\ProgramData\Autodesk\Revit\Addins\ and started re-enabling them one by one untill I got which plugin was the culprit.
MarkMoorhead
in reply to: yavork
Thanks very much for the reply, I'll give that a try.  Not sure how Autodesk can justify charging so much for maintenance when their support is so weak.
yavork
Well if you have the patience it usually gets escalated to the next level of Autodesk experts and eventually  ends up with the development team.
Good luck
