On Tue, 8 Sep 2009 00:34:42 +0000, hnakhla <> wrote:
>Hi,
>We're in the process of evaluating Revit Architecture 2010 and was wondering if there is an easy to use manual for network deployment and configuration.
Harry,
I've never found one. But it isn't too tough to setup. Just run the
network install to a shared location on a server, configuring it as
you go, and then run the client installs from that location. One
annoying thing I did discover with 2010: clients must now have full
rights to the install location. (with 2009 they only needed Read
Access).
Ken
Novell....it does a server good!
