Hi guys,
i installed revit architecture 2010 but I had some problems with library files. I can't install the "Help file".
When i try to download ITAHelp.cab from autodesk web site, revit give me ever an error.
Same thing when i try to insert ITAHelp.cab in the folder c:\users\account\AppData\Local\Temp.
My revit version is for student and then I've downloaded the file Help.cab from the Autodesk web site. Every time I open Revit I get the error screen that is missing the file help.cab.
Where i can insert the files whitout install them?
In which folder?
the files as you know are: HelpArchitecture.chm - rac_nfw.chm - TutorialsArchitectureMet.chm
thank you
