Revit Architecture
Revit Architecture
jon
Member
jon
Message 1 of 7 (444 Views)
Revit Architect 2013 does not detect correct NVIDIA driver
444 Views, 6 Replies
01-25-2013 12:25 PM
Hello All,
I have a problem with our Revit 2013 Architect installation.
The computer is an HP Z820 Workstation running Windows 2008 R2 with all the drivers properly installed. The graphic card is an NVIDIA Quadro 5000 and the installed driver for this card is 8.17.12.7642. This is the recommended driver version on Autodesk website. The problem is that when I check within Revit it does not detect the correct driver version and states that the driver is an older version. I have tried other drivers including the very latest directly from NVIDIA with no success. Does anyone know how to fix this problem?
Revit installation is on update 2.
With many thanks in Advance.
John
DarrenP
Message 2 of 7 (436 Views)
Re: Revit Architect 2013 does not detect correct NVIDIA driver
01-25-2013 01:14 PM in reply to: jon
you know revit is designed to run on server OS right
are you using citrix?
jon
Member
jon
Message 3 of 7 (421 Views)
01-25-2013 02:47 PM in reply to: jon
Thanks for responding.
No Citrix at this time. We are using RDP and Microsoft Remote App. However even if I directly run Revit on the console I still have problem detecting the correct driver version. Other than that The program runs very smooth for the most part
DarrenP
Message 4 of 7 (418 Views)
01-25-2013 02:50 PM in reply to: jon
just so you know this setup violates autodesk license agreement
i wouldn't worry about revit not detecting the correct drivers then
jon
Member
jon
Message 5 of 7 (411 Views)
01-25-2013 03:00 PM in reply to: jon
Even with Network license installed?
DarrenP
Message 6 of 7 (409 Views)
01-25-2013 03:02 PM in reply to: jon
jon
Member
jon
Message 7 of 7 (407 Views)
01-25-2013 03:03 PM in reply to: jon
Thanks for the advice. We will go that way. This is just a test right now to check the performance and find out if it works at all
